having running problems on a fresh rebuild :(
Thanks for taking the time too look at this
whats happened is i have a 3 door cossie but got it all built back together had the valves and spring done i had it going and left it to tick over on the spot for about 30 mins was sounding great
so i gave it a wee rev to about 1500-2000 rpm after that the car cut out and it sound like its running on 3 cilenders
i took the rocker cover gasket of because there was like a rattling noise(pretty sure its a tappet) from there i am not really mechanicaly minded anyway there was loads off oil so it wasnt short on oil
and i checked the tappets all them turned no probs in a circle motion with out ease except one on the inlet side(4th one) i tried quickly turning the engine quickly with out the rocket cover and all valves look likes they are all moving but as i said the tappets were all turning except one(in circle motion)could the stuck tappet be doing anything?its going up and down but not turning circle like the other onesis there a way i could fix this and whats the best way to do so i am pretty sure this is whats wrong with it? i checked the spark plugs and the 3rd on was diffrent from the rest had black shit stuck to it i changed the plug but no diffrence i have also check the spark seems finecould it be i have blowed a hose off?i doubt it i check all but you's know better than me
thank you very much for taken the time to read the and would really appriate any advice or tips
cheeRS
Craig
cheeRS
Craig
track.focus'd
Aug 12, 2015 05:53 PM
Zoggon
Aug 10, 2015 10:39 AM
