GT2860RS Turbine housing.
as above in T3 a/r.48 with internal wg. Is it possible to get? overkill to go external wg on this turbo,...Now running a/r.63 wich means too much lag,.
Can the housing on t25 escos be modified to fit?
Thanks!
Thanks!
the t25 small cossy exhaust housing will not fit as the the diameter where the core fit's
is smaller than the ballbearing housing ,also the turbine wheel is a bit different profile
Ford Focus RS Parts for Sale.
02-06-2016 06:46 PM
09-10-2015 07:38 PM
