E30 - 1 wheel sits differently to the rest?
Old Oct 24, 2008 | 03:04 PM
S2Steve's Avatar
S2Steve
Default E30 - 1 wheel sits differently to the rest?
I fitted new wheels to my E30 the other day and one of them sits differently to the rest, i never noticed it before on the standard wheels though... The guy at F1 tyres said my tracking was slightly out, but could not explain then difference in the way the two front wheels sit, he said maybe when suspension was changed it wasnt lined up poperly? Anyway here are pictures to show the differences between the two, oh and before anyone says, I know they're slightly illegal
Old Oct 24, 2008 | 03:11 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Looks the same to me, but the pictures are from slightly different angles. If you've not had the tracking done since you put the new wheels on, you're probably as well having it done.
Old Oct 24, 2008 | 03:12 PM
S2Steve's Avatar
S2Steve
Theres a lot more wheel and tyre visible on the passenger side, trust me!
Old Oct 24, 2008 | 03:38 PM
bristol_fez's Avatar
bristol_fez
looks like the camber is different.
Old Oct 24, 2008 | 03:41 PM
S2Steve's Avatar
S2Steve
Yes, it looks like all the wheels have a negative camber, apart from the passenger front which has absolutely none.
Old Oct 24, 2008 | 03:44 PM
fraser9764's Avatar
fraser9764
has it possibly had one new bottom arm?
Old Oct 24, 2008 | 03:50 PM
S2Steve's Avatar
S2Steve
Wouldn't know, not while i've had it anyway. I'm thinking maybe a bent strut?
Old Oct 24, 2008 | 05:25 PM
Daz T25's Avatar
Daz T25
hi m8. had a similar problem on my ecos turned out to be a bent strut! if you can get it on a ramp and measure the gap between the edge of the spring cup and the inner wing you should determin if this is the case without taking it apart! looks a good 20 mm difference to me!
Old Oct 24, 2008 | 05:34 PM
S2Steve's Avatar
S2Steve
I'll get the tape measure out tomorrow but I reckon it is bent, seems like the most obvious thing
Old Oct 24, 2008 | 05:40 PM
cossiecrew's Avatar
cossiecrew
try e30 zone mate
Old Oct 24, 2008 | 06:01 PM
S2Steve's Avatar
S2Steve
Haha i got two threads running, one here one on the zone
Old Nov 30, 2008 | 04:18 PM
S2Steve's Avatar
S2Steve
Anyone got any other ideas about this? I've been away for a while and only now have time/money to address the problem. Got tomorrow off so any suggestions on what to check/measure/look for?
Old Nov 30, 2008 | 04:21 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
front suspension control arms bend very easily with relatively small impacts. jack it up and compare the shape of the track rod ends.
Old Nov 30, 2008 | 04:31 PM
S2Steve's Avatar
S2Steve
Ok i'll have a look. This is right at the bottom nearest the wheel yes? I recall last time I had it up that the the rubber and the bolt did not sit flush, i.e. it looked slightly out of place...
Old Nov 30, 2008 | 04:33 PM
rapidcossie's Avatar
rapidcossie
different width wheels?
Old Nov 30, 2008 | 04:35 PM
S2Steve's Avatar
S2Steve
No, tried one of the other wheels on their and still got the same problem, wheels are all identical
Old Nov 30, 2008 | 07:21 PM
Alvyn's Avatar
Alvyn
2 different types of struts????
Old Nov 30, 2008 | 07:40 PM
fuzzy's Avatar
fuzzy
the track rod arms are a bent shaped anyway but an impact with a kerb or pothole can bent them out of shape.
Old Dec 1, 2008 | 01:49 PM
S2Steve's Avatar
S2Steve
Been out to look today...
Checking just by sight its hard for me to tell as i'm not sure what im looking for exactly. The two pictures below show either sides arms, now the first pic (the side with the problem), the arm appears to be angled down more so that the other, but its hard to tell.
Took closer pics of the arms/joints to see if anyone else can spot anything untoward...
Also as someone mentioned on another site, this doesn't look right either...
Old Dec 10, 2008 | 10:28 PM
fizzyturbo's Avatar
fizzyturbo
its either gonna be a slightly bent leg, are they the 51 mm struts? or possibly the wrong lower arm on the passenger side, possibly an m3 one cus of the slightly different track, possibilities, when have you noticed this first, and there is defferences in the bushes aswell, eccentric and concentrc, have u changed any bushes?
Old Dec 13, 2008 | 12:39 PM
S2Steve's Avatar
S2Steve
No, not changed any bushes...There is a lot more thread showing on the TCA on the passenger side compared with the drivers side...If the tracking is not out (whihc it isnt) does this point to them being different parts?
3drRich
Sep 13, 2015 07:32 PM
Marc sierra
12
Aug 30, 2015 10:38 AM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
saul1988
Wheels and Tyres
Aug 24, 2015 06:42 AM
A.t.p
Aug 15, 2015 11:37 AM
