escos running on two cylinders
Old Oct 24, 2008 | 01:09 PM
glancy2081's Avatar
glancy2081
Default escos running on two cylinders
as above escos only running on 2 cylinders number 3&4 and stays like this with the phase sensor plugged in or out .does that ean that the phase sensor is at fault
Old Oct 24, 2008 | 01:28 PM
Stu @ M Developments's Avatar
PassionFords Creator
No, sounds more like the head gasket has gone between 1 and two.
Old Oct 24, 2008 | 01:52 PM
glancy2081's Avatar
glancy2081
thanks will do a compression check then
Old Oct 24, 2008 | 02:39 PM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
I think read somewhere that martin hadland had this trouble with his mondy when he got it going again, Something to do with the ecu if i remember.
Cant remember exactly though. maybe he could help
dombanks
Sep 21, 2015 08:38 PM
gcfcos
Sep 11, 2015 06:03 PM
Mickeystewart
Sep 9, 2015 04:04 PM
cossirob
Sep 3, 2015 09:17 PM
