Please Help :(
Old Oct 15, 2008 | 02:17 PM
CRAIG HAYTER's Avatar
CRAIG HAYTER
Default Please Help :(
Hi I Am Having A Problem With The Spark On My 3 Door Cossie After The Engine Rebuilt The Engine Has Just Been Put Back In Is Cranking And Feulinng But The Spark Is Not Right It Is Sparking At Wrong Times And Not That Many Sparks Either Not Like It Should.i Tried New Spark Plugs,leads Etc Etc All The Obvious Things Even Tried Moving The Crank Sensor But Still No Joy Sound Like It Want To Start But Cant Tried Moving The Belt Round For The Timing Aswell But Still Nothing Can Anyone Please Help Really Needing This Done So Any Help Would Be Really Appreciated
Cheers For Taken The Time To Read This
Old Oct 15, 2008 | 02:40 PM
Stu @ M Developments's Avatar
PassionFords Creator
Assuming timing marks are correct on phase sensor then its likely that the Phase sensor plugged in backwards inside distributor.
Old Oct 15, 2008 | 02:47 PM
CRAIG HAYTER
yeah the timing marks seem to be fine "Phase sensor plugged in backwards inside distributor"will have a look at that anymore susgestion as it saves me a run down to the lock up thank you very much for help anymore susgestion would be great
Old Oct 15, 2008 | 06:30 PM
CRAIG HAYTER
Any More Please
Old Oct 15, 2008 | 08:54 PM
mikedaf2's Avatar
mikedaf2
Put the engine on TDC and make sure the rotor arm is pointing towards number one cylinder. There is also a groove in the distributor to line this up.
This is assuming you are still running the standard system.
Then check the connectors for the dissy and crank sensor have good connection and are the wright way round as i have seen these forced together the wrong way round before.
I would then check you have the right gap on the phase sensor and that the crank sensor is mounted correctly.
Old Oct 15, 2008 | 10:12 PM
CRAIG HAYTER
i love youthats what it it thanks very much thank you your a LEGEND
Old Oct 15, 2008 | 10:13 PM
CRAIG HAYTER
thank you aswell
Old Oct 15, 2008 | 10:23 PM
Your welcome mate, enjoy her.
Old Oct 15, 2008 | 10:29 PM
CRAIG HAYTER
you honestly dont know how happy you have made me i have waited about 14 months for thisthanks again
Old Oct 16, 2008 | 05:43 AM
stevecossy's Avatar
stevecossy
Stu saves the day again nice 1,
