Testing HT leads!!
Old Nov 11, 2004 | 09:09 AM
Blakeya's Avatar
Blakeya
Default Testing HT leads!!
Is it possible to test a set of HT off the car?? If so how do i do it & what should i be looking for? The leads in question are Beru leads off of a Cossie!!
Any help much appreciated
Regards
Andy
Old Nov 11, 2004 | 09:38 AM
nthorpey's Avatar
nthorpey
Only way I can think of is using a multimeter to check resistance of core is virtually zero and then a megger to check insualtion resistance is infinity.
Old Nov 11, 2004 | 03:12 PM
alan rainbow's Avatar
alan rainbow
check the risistance with a multi meter any think over 11k and there in the bin
Old Nov 13, 2004 | 08:19 AM
oriont's Avatar
oriont
is that true as they will all be varying resistances due to thier lengths been different?
thanks
oriont
Old Nov 14, 2004 | 10:48 AM
Dave Henshall's Avatar
Dave Henshall
the actual core resistance is negligably nil. the resistor is in the boot itself (and these are balanced to each lead to ensure they are all the same). cant remmeber off the top of my head ) 5 kohm rings a bell. -but they should ALL measure the same as they are balanced leads. cheaper silicone would leads WILL vary in resistance w.r.t. length as the core IS the resistor.
Old Nov 14, 2004 | 11:12 AM
oriont's Avatar
oriont
thanks for that.
i measured the resistance on my fiesta leads(standerd ford) and they go from 16K on no1 down to about 8K on number 4.
thanks
oriont
Old Nov 15, 2004 | 08:14 PM
Blakeya's Avatar
Blakeya
Cheers for the help Guys..
Measured the resistance of My Beru leads & this was the result..
Lead No 1 = 5.83 Kohms
Lead No 2 = 5.57 Kohms
Lead No 3 = 5.77 Kohms
Lead No 4 = 5.83 Kohms
Looks like I've got a good set
Andy
Old Nov 16, 2004 | 07:45 AM
Dave Henshall
biggidy bong
Old Nov 16, 2004 | 04:15 PM
alan rainbow
Andy
they are bang on 5k brand new and anything over 11k is scrap
Old Nov 16, 2004 | 08:16 PM
CosRush's Avatar
CosRush
Manual says 4500 to 7000 ohms....
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
The Youth.
Sep 30, 2015 09:59 PM
timsrs
22
Sep 24, 2015 08:14 PM
