help plaese!!! ecos balljoint
Old Sep 28, 2008 | 12:21 PM
martinembleton's Avatar
martinembleton
Default help plaese!!! ecos balljoint
best way to get the bottom balljoint back in its bein a right arse???
Old Sep 28, 2008 | 02:08 PM
martinembleton
anyone
Old Sep 28, 2008 | 02:54 PM
bannedalot's Avatar
bannedalot
if its locating near the hole in the strut just put a jack under it with slight pressure and tap the arm with a hammer
Old Sep 28, 2008 | 02:56 PM
martinembleton
tired that just wont go in
Old Sep 28, 2008 | 03:08 PM
bannedalot's Avatar
bannedalot
have you tried opening up the split that clamps together when the bolt is tight? A chisel should do it as well as cleaning up the ball joint itself with some sort of sandpaper. If you have access to a heat gun this will also help but mind all the rubber bits!
dirty-diesel
Oct 3, 2015 08:00 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
davecosworth
34
Dec 22, 2006 11:14 PM
Holty
Sep 8, 2004 11:03 AM
