sapphire4x4 oil separator
Old Sep 25, 2008 | 09:17 PM
proboscus's Avatar
proboscus
Default sapphire4x4 oil separator
i am in the process of fitting an oil separator to my sapph the cam cover has been drilled the kidney box has been removed and i will be using the original oil return port the kidney box was connected to as the return from the sdeparator.there was a pipe that went fronm the plenum cover to the kidney box as there is now nowhere to connect this to do i just block it off.also there is nothing else to that i have to do that i am aware of am i right in thinking this?
Old Sep 25, 2008 | 10:07 PM
LHD220Turbo's Avatar
LHD220Turbo
what breather do you have? is it this type set up? if so this is how you do it
Old Sep 26, 2008 | 06:02 PM
proboscus's Avatar
proboscus
yes that is the separator can i connect the return pipe to the original return just in front of where the original kidney box sat if not do i haveb to block off that outlet and connect it to the turbo side as you say.also do i need any sort of flame trap anywhere?
Old Sep 27, 2008 | 12:04 AM
LHD220Turbo
you need to buy the screw in adapter with fits on the bottom of the block (turbo side)
from factory this is blocked off
cheers
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
deathrider666
Sep 28, 2015 06:12 PM
