rev counter showing half revs!!!!!!!!!!
Old Sep 12, 2008 | 05:15 PM
16vzetec's Avatar
16vzetec
Default rev counter showing half revs!!!!!!!!!!
just fitted rs2000 1992 ecu and loom.
the rev counter is at half revs, the green wire from the engine loom only makes half revs and i need full revs for the rev counter i have got.
does anyone know where to connect it so i get full revs?
there is no green wire from the edis module like on most ford looms
Old Sep 12, 2008 | 05:38 PM
If your car/tacho was originally for a std type coil, then this can be fixed easy with a tacho driver, about Ł30, this would then give you the correct square wave that the early tacho's need.
Old Sep 12, 2008 | 05:50 PM
dannyb's Avatar
dannyb
I think i remember someone using the clocks from a EFI Model 3i to get round this?
Old Sep 12, 2008 | 07:10 PM
16vzetec's Avatar
16vzetec
i brought an aftermarket rev counter coz the efi clocks are at half revs too but the new one does it too
Old Sep 12, 2008 | 07:27 PM
dannyb's Avatar
dannyb
Have you seen this thread? worth a try
https://passionford.com/forum/showth...+counter+zetec
Apparantly megasquirt site shows you how to get round it but not seen that myself
Old Sep 12, 2008 | 10:33 PM
Rs-Simon's Avatar
Rs-Simon
Try this as it worked on my EFI conversion.
Old Sep 13, 2008 | 05:17 PM
VEEDUBBED's Avatar
VEEDUBBED
What can 1 do if the original rev counter was driven by the O/E ecu??
Old Sep 26, 2008 | 04:01 PM
16vzetec's Avatar
16vzetec
fixed it and did a guide to help;
http://www.feoc-uk.com/forums/index.php?showtopic=60953
boeb
Jan 9, 2020 05:11 AM
stevecfrst1
Sep 30, 2015 05:18 AM
