Zetec quickys
Old Sep 6, 2008 | 07:52 PM
dannyb's Avatar
dannyb
Default Zetec quickys
Just bought my zetec for my mk4 3i and need to know the following,
Also noticed its already fitted with the Escort 1800 inlet so does this go into the mk4 bay?
The engine is 2.0 with the 1.8 bits on i know its not ideal but would the ECU from a 1800 zetec run it whilst i mess about installing it as i have a 115bhp 1800 Escort with chip key etc
Thanks for any help
EDITED becouse i managed to sort a few probs
Old Sep 8, 2008 | 06:44 PM
dannyb's Avatar
dannyb
Anyone
Old Sep 8, 2008 | 06:58 PM
Pob's Avatar
Pob
I'm sure it'll fit, i've seen mk1/2/3 fiesta/ford ka's with this engine arrangement in them.
Why don't you get a cheap mondeo ecu/throttle housing from a local scrappy.
Info here, its probably on this site but the search doesn't like me for some reason ;-(
A full guide to fitting a zetec in a fezza, very similar to a mk4 i would think. I'm sure some one will kick my teeth in if i'm wrong though
http://www.ford-force.com/forums/ind...showtopic=6381
Find the parts to upgrade to 130 spec
http://www.ford-force.com/forums/ind...showtopic=2527
Old Sep 8, 2008 | 07:52 PM
dannyb's Avatar
dannyb
Cheers the 1800 bits i mentioned are the flywheel sump etc, its still got the 2.0 cams , throttle body etc, I need to find out if it will run on my 1800 ECU (will have to swap somw wires about) for testing it whilst i get a 2.0 Mondeo EU
Also not sure if the 1800 Inlet goes in the mk4 bay. Will have a look at the links now cheers
Old Sep 8, 2008 | 07:59 PM
rst in breaking's Avatar
rst in breaking
the inlet will fit the mk4 bay as far as im aware mate but with regards to the ecu your best just getting the right one so it fuels correct etc as they're peanuts
Old Sep 8, 2008 | 08:12 PM
dannyb's Avatar
dannyb
Cheers Would have been nice to get it running on the 18 ecu if only so i can ebay it as tested lol
Old Mar 3, 2009 | 12:27 PM
sambo170588's Avatar
sambo170588
sumone be king and answer my question please would a 1.8/2.0ltr throttle body injecters maf sensor and ecu fit and work on my mk6 escort 1.6 zetec then obv get it rolling road tested??????????? help much apprictaed
Old Mar 3, 2009 | 12:59 PM
xrmalin's Avatar
xrmalin
no in a word your better just changeing the hole lot to a bigger engine to start with
mark
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
SMILER258
Sep 28, 2015 09:04 AM
mondeomark
Sep 28, 2015 06:28 AM
focuspower
Sep 20, 2015 03:51 AM
