Is this dangerous??!!
Old Aug 30, 2008 | 09:08 PM
godzilla's Avatar
godzilla
Default Is this dangerous??!!
My Escort estate 1996 1.6 Zetec makes creaking noises when applying the brakes or foot off throttle. The noise is coming from the front. On acceleration it goes. When I pushed both wings the passenger one was fine but the drivers side makes a creak...... what could it be?
Also...... My temp gauge does not work, any ideas?
Old Aug 30, 2008 | 10:19 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Temp gauge could be something as simple as the sender's connector has popped of the sender. 5 second job once you've found it
If it's creaking when you brake, and when you lean on it, you might just have a slightly binding caliper or drum that needs seeing to. By the sounds of it, it's the drivers side front caliper. For a quick check, jack it up on each side and spin the wheels by hand - they should both spin quite freely.
Old Sep 1, 2008 | 10:02 PM
westus1's Avatar
westus1
the front brake flexi pipes are very common on these models for going faulty, the inside of them collapses and dont let fluid return to the master cylinder so if the caliper is sticking try opening the bleed nipple and if the piston then moves freely then its just the flexi hose that needs replaced
Old Sep 2, 2008 | 07:16 PM
godzilla's Avatar
godzilla
Ok!! Jacked her up earlier. The drivers wheel hardly moved!! I hit the brake caliper with my hammer and squirted tons of WD-40 all over the caliper.....its a bit better now!
How do I bleed a brake caliper nipple, what tools do I need?
Old Sep 2, 2008 | 09:03 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Glad you found the problem mate But it sounds like you need to have that caliper refurbished - usually costs around £90, and is much better in the long run. You'll pat yourself on the back afterwards
Any garage should be able to get it done for you.
To bleed a nipple (sounds so wrong ), on the inboard side of the caliper, there should be a small cap, like a tyre valve cap. That covers the bleed nipple to keep the grit and muck off it. For the bleeding procedure, take a look in your Haynes comic - an essential tool - that'll have the whole procedure.
Old Sep 2, 2008 | 09:16 PM
SumpNut's Avatar
SumpNut
I'm in MK dude, if you ever need advice or someone to give you a hand/point you in the right direction on the car give us a shout.
I recently rebuild the calipers on my saph, its an easy enough job to do when you need that doing.
Old Sep 2, 2008 | 09:21 PM
godzilla's Avatar
godzilla
Thanks mate
If I could drop my car off with you one day/weekend would you mind doing them for me? Also the cambelt needs doing.....can you do that?
I will pay you in cash for any work carried out.
Will PM you my number now.
Old Oct 22, 2009 | 10:51 AM
TurboShed's Avatar
TurboShed
Cossiemodo
1. WD40 won't help your brakes perform
2. WD40 causes rubber to perish, which you don't want.
Old Oct 22, 2009 | 11:09 AM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
spring snapped?
usual reason for creak from 1 shock, calipers dont usually creak, escort calipers are shite for sticking too
pick up a good rs2000 front brake set up maybe on escort evo
Old Oct 22, 2009 | 03:28 PM
The calipers on your car should only be around £35 exchange recon.
datar18
38
Apr 15, 2005 01:42 AM
cossiecrew
12
Jan 25, 2005 09:23 PM
andy_turbo1987
43
Jan 24, 2005 06:48 AM
paul220tcoupe
Aug 19, 2004 03:18 PM
