Hesitant acceleration
Old Aug 26, 2008 | 06:27 PM
notroubleclubber's Avatar
notroubleclubber
Back In The RS Game!
Default Hesitant acceleration
Hi. I have a s2 erst. I have notcied when accelerating, btwn 2-3000rpm it stutters and hesitates but if i put my foot furthur down on the throttle it clears and pulls cleanly. It seems to do it at a certain point when holding the accelerator.
Could this be throttle posiition sensor? Only thing is it doesnt do it when in neutral, seems to rev ok then. Im thinking this as my nan owned the car before me from new and she wouldnt have ragged it and would have drove with the accelerator at that position all the time!!!!
Is there anyway of testing the throttle position sensor with a digital multimeter? Or anyway of cleaning it up and improving it without replacing it?
Old Aug 26, 2008 | 10:31 PM
cozmeister's Avatar
cozmeister
More boost Igor!
If it doesn't do it when there's no load on the engine (ie, in neutral), I'd point at the MAP sensor as that's how the ECU determines the load being put on the engine - but I'm not an expert with MFI, so don't know if it has one to start with.
Old Aug 27, 2008 | 06:01 AM
notroubleclubber
got a feeling my engine doesnt have a map sensor.
Old Aug 27, 2008 | 06:37 AM
rickbartlett's Avatar
rickbartlett
G911 TTA
no mfi doesnt have one.try changing the plugs,mine did that wen they were all coaked up
Old Aug 27, 2008 | 06:48 AM
notroubleclubber
changed plugs, tho im gonna get a new dizzy cap and rotor arm, also leads when funds allow.
Old Aug 27, 2008 | 10:15 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Didn't think so, but at least a few other people have thrown some good suggestions in
Old Aug 28, 2008 | 06:55 AM
notroubleclubber
yeah, im finding this site isnt as helpful as others
Old Aug 28, 2008 | 04:06 PM
cozmeister's Avatar
cozmeister
More boost Igor!
I try and offer something if I think I can help - it's rude not to. I know how annoying it is to not get answers for questions that aren't related to 6 degree beams or turbine housings.
Old Sep 2, 2008 | 01:10 PM
turbo nut's Avatar
turbo nut
i had a similar problem with my series 2,it was hesitating a lot between 2500 and 3500 rpm so i checked the spark plugs and ht leads and the distrubutor cap all was fine,so i went to drive the car and it pulled away fine but then died (cut out),i found out that the distrubutor was nackered ,so i fitted a new one and now it is running like a dream
Old Sep 2, 2008 | 02:30 PM
notroubleclubber
Got alot of welding to get done, mot and new clutch to fit, then i can fault find. The other day i drove it and it was fine!!!
IainRS1700T
Sep 25, 2015 06:44 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
landaqmabba
Sep 15, 2015 07:16 PM
Marino
Sep 12, 2015 11:10 AM
