Lumpy Idle at tick over - DOHC 16v I4
Old Aug 26, 2008 | 11:09 AM
R7BKR's Avatar
R7BKR
Default Lumpy Idle at tick over - DOHC 16v I4
I hope someone can throw some light on this.
I have a 1996 (N plate) RS2000 with the original 2.0 Zetec engine.
When I first start it in the morning the engine runs really 'lumpy' and the revs seem to 'hunt' between 1000 and 1250 until the engine has been run for a little while. It only ever settles down to just under 1000 rpm once the engine is up to temperature, and the 'lumpiness' is still noticable after that.
Any ideas what could be wrong?
I need to arrange an oil change as I am not sure the correct oil was added at the last oil change (5W 30) and I don't think this is helping either.
Cheers, Roy
Last edited by R7BKR; Aug 26, 2008 at 02:29 PM. Reason: Incorrect engine described.... D'oh
Old Aug 26, 2008 | 11:20 AM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
IDAL CONTROL VALVE ITS NEAR THE THROTTLE BODY x2 8mm bolts hold it on take if off and clean it out with carbe cleaner the re lube with wd-40 also chech for air leaks
Old Aug 26, 2008 | 11:51 AM
R7BKR's Avatar
R7BKR
Cheers, I'll have to give that a try.
Old Aug 26, 2008 | 02:25 PM
R7BKR's Avatar
R7BKR
Susequently found out that the engine in the RS I have is the DOHC 16V I4 engine and not the Zetec as previously thought.
Sorry for the confusing people
Old Aug 26, 2008 | 03:10 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
Have a good look round for air leaks after the MAF.
Old Aug 26, 2008 | 03:57 PM
iansoutham's Avatar
iansoutham
OCD Victim
Has it got a cone filter on it?
Had exactly this problem on a friends' N-reg RS2k and as soon as the original airbox went back on, the problem went away, even after doing a KAM reset, etc...
As above though, I would check the ISCV as well out of principle to make sure it is cleaned out as these are a known problem on ALL Ford models.
BTW: correct oil for these engines in 16V form is 5W-30, 10W-40 if it was an 8V as found in the Sierra and Granada models.
Old Aug 27, 2008 | 07:30 AM
R7BKR's Avatar
R7BKR
The engine is totally standard and yes it still has the airbox fitted to it.
I think cleaning the Idle value, changing the oil and air filter are the first jobs on the list.
I had a look for the Idle control valve and couldn't locate it (sorry I'm I real novice where engines are concerned).
Do you have, or know where I can get hold of an diagram/ picture of the I4 so I can work out from that were the stuipid thing is?
The I4 does have what looks like a control value attached to the airbox so was unsure as to what that was.
I have taken some pictures of my engine and can post them later this evening if this doesn't make any sense.
Cheers for all your help on this.
Roy
fordrallycar
Sep 30, 2015 07:57 PM
liamT74
Sep 23, 2015 10:24 PM
mike elsome
Sep 14, 2015 04:08 PM
RSmark84
Sep 13, 2015 01:29 PM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
