rst none starter
Old Aug 24, 2008 | 09:12 PM
slimjules's Avatar
slimjules
Unhappy rst none starter
hey newbie here just after buying s2 rst but she wont start no dash lights nothing at all had a friend with a multimeter go through the car and he said there is no power in the ignition and the alarm but there is power at the alternater and starter and he said every where there should be power in the car there is ground.right strange one have anybody came across this problem before
Old Aug 24, 2008 | 09:17 PM
D16PJM's Avatar
D16PJM
if theres power to the Alternator there should be power to the clocks or battery light as the power loops through the clocks from battery to alternator sounds like an alarm issure to me
Old Aug 24, 2008 | 09:49 PM
Shep_Cobain's Avatar
Shep_Cobain
yeh...
Old Aug 24, 2008 | 10:19 PM
slimjules's Avatar
slimjules
was thinking that the alarm was the issue allright but would the alarm shut the whole car down
Old Aug 25, 2008 | 07:12 AM
A decent immobiliser can do this, depending on where the power is interupted, but is dead easy to find.
Old Aug 25, 2008 | 10:07 AM
Shep_Cobain
On my old XR3i the immobiliser was fooked, the car wouldnt start and had no power etc as though the battery was dead. I d/c the battery left it for 10 minutes, re-connected it and the immobiliser had disarmed itself and it started fine.
Old Aug 25, 2008 | 05:54 PM
slimjules's Avatar
slimjules
would i have to trace wires from the the alarm and immob to solve my problem
Old Aug 26, 2008 | 10:38 PM
slimjules's Avatar
slimjules
got her turning today but no power to the fuel pump
Old Aug 28, 2008 | 08:59 PM
slimjules's Avatar
slimjules
think i found my problem the brown wire that primes the fuel pump relay has no power only earth where does this wire run to from the relay and could my alarm or immob be connected to it which causes my problem?
Old Aug 28, 2008 | 09:38 PM
northernmonkey's Avatar
northernmonkey
I didn't do it!
your immobiliser is almost definstley connect to the fuel pump, put 12 volts down there and try again
A.t.p
Oct 23, 2015 07:54 PM
cossie362
Oct 11, 2015 03:53 PM
Billy_RS
Sep 13, 2015 04:17 PM
marky_g
Sep 12, 2015 04:26 PM
