Anti theft system help......urgent!
Old Aug 24, 2008 | 12:17 PM
cosrep's Avatar
cosrep
Default Anti theft system help......urgent!
On a mk6 escort if the red light under the clock stays illuminated does this mean the system is activated i.e will prevent the starter motor turning over?
With the doors unlocked as normal I have ignition lights but the engine wont turn over, The dash lights dim slightly when I try start it. It will start with a push though which I thought shouldn't happen....confused.
Old Aug 24, 2008 | 12:20 PM
taycoss's Avatar
taycoss
the car will still turn over with imob on just wont start,sounds more like battery problem or starter.Try a 12v feed to the starter exciter terminal.
Old Aug 24, 2008 | 12:22 PM
cosrep's Avatar
cosrep
Normally I would have come to the same conclusion but the problem only started after the battery was disconnected for a half hour to reset the ecu
Old Aug 24, 2008 | 03:38 PM
Next time just pull the KAM fuse a violet 3 amp job as this is the memory one for the ecu.
Usually the pats just stops the ignition, did on mine anyway, when it went for a swim.
Nov 1, 2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Fezman1
Oct 2, 2015 01:22 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
