-31 Actuator
Old Aug 19, 2008 | 06:29 PM
Pat's Avatar
Pat
Default -31 Actuator
I`m lookin to put a new actuator on my S2 ERST.. As my old ones seem to be weakening...
I`m running quite a high spec engine 2.1zvh, T34 hybrid etc etc mapped to hold 24psi.. My question is if i`m going to buy a new actuator is there a certain make i should buy..
Old Aug 20, 2008 | 12:45 AM
Simmo's Avatar
Simmo
Probably just sticking with the sealed Garrett type from Burtons, Woodford etc is the best bet...
Old Aug 20, 2008 | 06:51 AM
s1cab's Avatar
s1cab
on a t34 i'd go for a -34 garrett actuator !
Old Aug 20, 2008 | 07:13 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
And why is that?
Only use genuine Garrett -31's.
Old Aug 20, 2008 | 07:30 AM
JohnP001's Avatar
JohnP001
I thought that the different types, eg -31, -34 refer to a different spring tensions within the actuator. I’m sure some one will correct me if I’m wrong.
Personally I’m running a -47 actuator on my Escort Cosworth, as this is what suits my engine specification.
Before my engine rebuild/upgrade I replaced my standard actuator with a -31, and worked fine.
Have a look at to what you have installed, as you should see some markings on the actuator, and make a decision from there.
John
Old Aug 20, 2008 | 05:49 PM
s1cab's Avatar
s1cab
Originally Posted by pa_sjo
And why is that?
coz im running high boost and kept going through -31's i found the spring too weak. now ive got a -34 fitted its lasted ages.
Old Aug 20, 2008 | 05:50 PM
s1cab's Avatar
s1cab
John
thats correct ! just different spring tensions!
JK12
33
Apr 26, 2021 12:09 PM
steve.rst
Mar 15, 2016 08:01 AM
A.t.p
Sep 29, 2015 05:04 PM
rs_jim
Sep 19, 2015 08:41 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
