escort s2 turbo
Old Aug 19, 2008 | 04:29 PM
cossie212000@'s Avatar
cossie212000@
Default escort s2 turbo
hi i changed the standard acutater for a -31 item now the dunmp valve doesnt go off but the turbo holds boost any ideas cheers
Old Aug 19, 2008 | 04:50 PM
dom123's Avatar
dom123
is the vacum pipe still connected from the inlet to the top of the dump valve?
Old Aug 19, 2008 | 05:14 PM
cossie212000@
yesw mate i have checked all vacum pipes boost pipes still no change cheers
Old Aug 19, 2008 | 06:12 PM
peachy's Avatar
peachy
Perhaps the Dumpvalve has ceased???
Try another it wouldnt be the first. I take it the boost pressure is still the same as before with the standard actuator?
Old Aug 19, 2008 | 08:10 PM
cossie212000@
hi the it is boosting slighty better holding 1/2 bar at idle and goes to one bar on boost where before it was slightly worse
Old Aug 19, 2008 | 08:23 PM
rs-nut-john's Avatar
rs-nut-john
Take the actuator off and see if the wastegate is moving freely, not sure if this would effect the dump v going off but might explain the boost prob
Old Aug 19, 2008 | 08:34 PM
peachy's Avatar
peachy
Its sitting at 1/2 bar at idle??? It should be negative during idle!!! This aint correct, i would look at that!
Old Aug 19, 2008 | 09:28 PM
s1cab's Avatar
s1cab
def shouldn't be on boost on idle !! very wrong!! how much preload did you put on the new actuator?? coz if theres no preload then your wastegate will be permanently open. is it pulling the same as before??( as in same amount of lag or more lag??) when its on full boost??
3i Jim
Nov 20, 2015 05:12 AM
Matt Baxter
Sep 16, 2015 08:30 PM
FlashRS
Sep 14, 2015 12:36 PM
muz
Aug 16, 2015 12:57 PM
adriansaleem
Aug 1, 2015 09:28 PM
