low comp engine
Old Aug 14, 2008 | 06:28 PM
mark2's Avatar
mark2
Default low comp engine
hi ladies and gents
i am looking for some info on the cvh turbo lump
is there anyway of checking if an engine is a low comp or standard
was thinking on the lines of a compression test but if the reading was low might meen a fault with an engine component or does a low comp engine produce a lower compression reading
i must state the engine is in the car running and is stated tobe a rebuilt low comp engine but no paper work as all paperwork was in a leather folder which went missing when it was broken into and the car does come with a spare pass side glass tobe fitted
this is another series 2 i am looking to buy ,done all the standard checks and the car is loaded with engine mods as stated which i have confirmed myself and found tobe true ie cam,turbo,ecu,breather system,fueling,actuator and ignition but when it comes to the engine being low comp i am puzzled unless i strip it and take measurements and i am sure he want let me do that
hope someone can help
mark2
Old Aug 14, 2008 | 06:41 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
if the piston has a bowl in the centre (i.e. low comp) then it's feasable you could measure the top of piston through spark plug hole...compare it to standard and if it's a longer distance it's conceivable that the piston bowl is lower meaning lower comp than std.
You could also whip the sump off and have a look at the underside of the pistons, if they say a manufacturer or codes on them it might shed some light to the situation.
Good luck
Dan
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
Ben26
Aug 27, 2015 08:56 PM
ekjim
Aug 17, 2015 08:57 PM
MadsBL
Wheels and Tyres
Aug 6, 2015 10:04 AM
