Sierra Diesel question...
14-08-2008, 11:39 AM
I thought someone here might know if any sierra diesel model has a tachometer fitted as standard equipment..??
14-08-2008, 12:33 PM
I had a 1.8td which had a clock fitted in the place of the tacho, I think the 2.3 was the same too.
14-08-2008, 09:43 PM
yes a gls or glx td do have rev counter fitted
15-08-2008, 05:44 AM
I never knew that, at least then it's easy to add as they most likely just used the same alternator across the range.
15-08-2008, 06:24 AM
Resident Wrestling Legend
the diesel uses an output from the alternator so you need to have a specific diesel rec counter
wowk
30-03-2021 07:49 PM
chowfornow
14
05-01-2019 09:01 PM
01-11-2015 06:53 PM
Fil
30-09-2015 12:08 PM
SMILER258
28-09-2015 09:04 AM
