broken actuator
Old Aug 9, 2008 | 09:40 PM
supermanrs's Avatar
supermanrs
rs turbo newbie
Default broken actuator
how can i tell if my actuator is worn? i can pull the bar right out with 2 fingers. would this explain why my boost peaks at 18psi but falls right off to 8??
Old Aug 9, 2008 | 09:48 PM
Stu @ M Developments's Avatar
PassionFords Creator
Very likely, yes.
Old Aug 10, 2008 | 09:42 AM
johnenright150rst's Avatar
johnenright150rst
yeah had the smae trouble mate, get your self a nice new -31 orderd up give it about 3 mil pre load and you be sorted.
Old Aug 10, 2008 | 10:05 AM
Phil2002's Avatar
Phil2002
supermanrs you've decided to keep it then!!!!!!
see the car in the sig!!!
Old Aug 10, 2008 | 04:58 PM
supermanrs's Avatar
supermanrs
rs turbo newbie
is that the rs in ure pic then phil??
Old Aug 10, 2008 | 04:59 PM
supermanrs's Avatar
supermanrs
rs turbo newbie
when u say a 3mm preload, does that mean leave it 3mm short of the wastegate flange b4 hooking it on??
Old Aug 11, 2008 | 07:39 PM
Phil2002's Avatar
Phil2002
yes mate that is the very car you talk of.
Old Aug 11, 2008 | 07:43 PM
peachy's Avatar
peachy
sounds like the actuator to me. When fitting a new one screw the rod till its hole looks like a half moon over the wastegate pin then pull the rod over the pin, this usually sets it up fine. Would reccomend a good tune tho
steve.rst
Mar 15, 2016 08:01 AM
mjonathan24
Oct 29, 2015 10:39 PM
A.t.p
Sep 29, 2015 05:04 PM
rs_jim
Sep 19, 2015 08:41 PM
