s1 idle problem
Old Aug 5, 2008 | 05:53 PM
allang86's Avatar
allang86
Default s1 idle problem
just fitted a 2nd hand engine in my s1 that had done 12k. got car started but cuts out every time at idle, engine will keep running if i rev it, any ideas
Old Aug 5, 2008 | 08:38 PM
Series1Dry's Avatar
Series1Dry
Cold start valve possibly. If you keep it revving so it does'nt stall for a minute or so after starting, is it ok then ?
Old Aug 6, 2008 | 05:07 PM
allang86's Avatar
allang86
no car still cuts out after revving it for a minute
Old Aug 6, 2008 | 07:16 PM
diesel's Avatar
diesel
it could be a air leak check all the boost hoses and the breathers
my car had a problem like that it was the breather on the meter unit popped off the one coming from the rocker cover to the meter unit
have a good look
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
