2001 Focus Heater / Blower
Old Aug 5, 2008 | 07:08 AM
1965otis's Avatar
1965otis
Question 2001 Focus Heater / Blower
Hi,After reading other Threads on the problem of the blower only working on No.4 I bought a new resistor. Still got the problem, I didn't get any new wiring with it but the old wires look fine - can you tell visually if they have blown?If this is not the problem where do I go next? & is it solvable by a novice, is it a garage job?Cheers
Old Aug 5, 2008 | 10:34 PM
Scottfocus's Avatar
Scottfocus
passenger side look up the foot well towards the centre collum, there is a square box plugged in you cannot miss it, change that , problem solved.
Old Aug 7, 2008 | 07:23 AM
Just do a continuity check on the resistor will tell you if any good, yes you can see the broken wires on the resistor if broken.
As you are getting power at the switch, you need to follow this along to resiustor etc and see where the problem is, no 4 full speed merely buypasses the heater resistor.
Mile30
69
May 13, 2017 08:44 PM
Chas
Oct 5, 2015 07:13 PM
Flatlinedan
Sep 18, 2015 12:41 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
