help on escort cossy
Old Jul 26, 2008 | 09:51 PM
rslrallye's Avatar
rslrallye
Default help on escort cossy
can any one help me out i have a 94 escort cossy and i need to know the ecu pin outs asap
Old Jul 26, 2008 | 09:55 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Pin 1 starts at the open end of the plug.
pin out is :
1 POWER GROUND
2 LAMBDA SENSOR INPUT
3 CRANK SENSOR GROUND
4 CRANK SENSOR INPUT
5 PHASE SENSOR GROUND
6 KNOCK SENSOR GROUND
7 PURGE VALVE
8 DIAGNOSTIC SOCKET
9 VREF MONITOR
10 POWER RELAY EARTH
11 VREF NEGATIVE
12 WARNING LAMP OUTPUT
13 OCTANE ADJUST
14 OCTANE ADJUST
15 MAP SENSOR INPUT
16 BOOST VALVE
17 THROTTLE POSITION
18 INJECTOR 4
19 POWER GROUND
20 POSITIVE SUPPLY
21 NOT USED
22 KNOCK SENSOR INPUT
23 PHASE SENSOR INPUT
24 IGNITION TRIGGER GROUND
25 IGNITION TRIGGER OUTPUT
26 SPARE
27 DIAGNOSTIC SOCKET
28 FUEL PUMP RELAY
29 COOLANT SENSOR
30 VREF POSITIVE
31 CHARGE AIR SENSOR
32 INJECTOR 2
33 INJECTOR 3
34 IDLE SPEED VALVE
35 INJECTOR 1
_________________
Old Jul 26, 2008 | 10:29 PM
rslrallye's Avatar
rslrallye
thanks so much mate
Old Jul 27, 2008 | 09:07 AM
rslrallye's Avatar
rslrallye
forgot to ask is this for a big turbo escort
Old Jul 27, 2008 | 09:08 AM
Richie.'s Avatar
Richie.
aka Turbosailorboy
Yes
Old Jul 27, 2008 | 09:40 AM
rslrallye's Avatar
rslrallye
thanks very much
Billy_RS
16
Oct 11, 2025 09:41 PM
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
stickyslick
14
Aug 10, 2015 06:27 PM
