Shell Prep
Old Jul 24, 2008 | 12:12 PM
AdamS2's Avatar
AdamS2
Default Shell Prep
Spent the past week off and on doing the welding on my S2 RST.
As the car is pretty much a shell at the moment I was looking at seam welding/strenthening. Will be running a rear cage and want the car to be as solid as possible.
In a nut shell:
Can pop rivets be used in the same way as you would seam welding?
Are there advans and disadvans to each method?
Should I stop being so lazy and get on with the welding?
Thanks.
Old Jul 24, 2008 | 06:02 PM
groomers's Avatar
groomers
if you are gonna do it do it properly pop rivits arent stong enough for stengthening!
bobsworth
77
Mar 24, 2016 09:30 PM
gambo08
Feb 4, 2016 10:49 PM
Fil
Sep 30, 2015 12:08 PM
SMILER258
Sep 28, 2015 09:04 AM
