comp brake compression struts, knocking!
Old Jul 23, 2008 | 06:12 PM
adam151082's Avatar
adam151082
Default comp brake compression struts, knocking!
i have just fitted some comp brake compression struts on my 3dr and now when i drive it it sounds like a bush has gone,since fitting the only bushs is in the bottom arm where it bolts to the sub frame. any1 else have this problem? ive checked and nothings loose.
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
