Saph Cossie 4x4 water pump
Old Jul 23, 2008 | 10:17 AM
spamjock's Avatar
spamjock
Question Saph Cossie 4x4 water pump
Has anyone ever successfully repaired a Cossie 4x4 water pump. Mine started leaking around the bearing bush when I assembled the car after bending 16 little capped rods when a rubber belt stripped its teeth. Maybe there's someone out there using a good used pump as for a paper weight? Help someone, I'm from South Africa and there's very little help here.
Old Jul 23, 2008 | 10:21 AM
rog's Avatar
rog
Not sure if you can fix them mate, probably better of just getting a new one, especially if your considering buying a 2nd hand one that has been lying around for a bit. Mine was ok, but the car was off the road for 2 years and when i had it all back together the pump leaked like sieve as the seals had all dried out.
Old Jul 24, 2008 | 12:30 PM
spamjock's Avatar
spamjock
Default saph cos 4x4 water pump
Thanks for responding Rog. Found engineering works willing to give it a go even if it means sawing off the spindle, fit new bearing plus bush and reweld. I'm desperate for transport so either he does it or I give it a go. Cheers, keep well.
DixieTheKid
Jul 23, 2023 10:16 AM
cameron2
Aug 25, 2015 07:18 AM
lukeeboy149
Aug 22, 2015 04:29 PM
MARKYMARKONE
Aug 20, 2015 12:55 PM
gcfcos
118
Aug 18, 2015 05:53 PM
