S2 electric windows
Old Jul 18, 2008 | 04:21 PM
Rs-Simon's Avatar
Rs-Simon
Default S2 electric windows
Passenger window wont go down, tryed 2 motors and still the same. Checked the power with light probe and when I press the down button I have power both sides of the motor, also I changed the switch. So I have come to the conclusion of a relay, anyone know where it is or what else it could be. Thanks
Old Jul 18, 2008 | 05:42 PM
fonfe's Avatar
fonfe
there are two plugs that come off the motor, turn one of these the wrong way round (you will have to bend the clip fingers back to do this) and it wil reverse the switch and it should go down when you press up, if this happens then you have a break in the wires from the passenger side to the drivers side, the window will not work if there is a break, find whic wire by taking off both door cards and testing for continuity along the wires untill you find the broken one.
chowfornow
14
Jan 5, 2019 09:01 PM
Nov 1, 2015 06:53 PM
stevecfrst1
Sep 30, 2015 05:18 AM
cossie330
Sep 27, 2015 04:13 PM
IainRS1700T
Sep 25, 2015 06:44 AM
