suspension stiff as..!?
Old Jul 16, 2008 | 07:28 PM
Pob's Avatar
Pob
Default suspension stiff as..!?
Hi, guys and gals
I've recently had to change the drivers side-
bottom arm,
bottom arm-to body shell bracket,
the hub,
disc/cailper
The car is a 99 model ford ka, the parts mentioned above are from a 97 model!
I've adjusted all the dampers off, all around the car, but the drivers side front is solid.
It doesn't bounce!!! Nothing shifts it, i've had that damper off+checked it, everything works okay. Put it back on+still stiff.
I also had to change all the shocks to Gaz dampers all around the car.
I did have to change the rear beam from the fork to slot type.
So can any one shed any light on this?? I'm p***ed off. A full week of head scratching and stripping and rebuilding and i'm sick!
Andrew
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
