lumpy tick over
Old Jul 12, 2008 | 05:40 PM
proboscus's Avatar
proboscus
Default lumpy tick over
when starting my cossie it is very irratic on tick over until it reaches running temperature
could it be time for a new set of plugs or are there any common faults that cause this?
Old Jul 12, 2008 | 05:47 PM
rossco22's Avatar
rossco22
Could be the plugs or maybe try a new idel control valve , mines abit lumpy for a few secs when its cold next time you start it from cold disconnect the icv if its the cause of the problem it should tick over at about 700 rpm smoothly....
Old Jul 12, 2008 | 06:39 PM
KSA-Cossie's Avatar
KSA-Cossie
Maybe fueling needs checked to.
Old Jul 12, 2008 | 06:42 PM
rapidcossie's Avatar
rapidcossie
700 rpm is too low.
Old Jul 12, 2008 | 06:57 PM
rossco22's Avatar
rossco22
700 rpm is too low.
Agreed but that should rise slightly onces its warmed up...,, this is only to check if the fault does lie with the icv or not..
Old Jul 13, 2008 | 07:43 AM
I would check the mixture first.
Fiddy
21
Sep 29, 2015 06:10 PM
dojj
Sep 8, 2015 08:31 AM
stevierob
Sep 7, 2015 07:09 PM
Adam-M
22
Aug 10, 2015 10:46 AM
mattman1234
24
Aug 1, 2015 11:46 AM
