!!!!! Help Help Help Help Help Help !!!!!
Old Jul 9, 2008 | 03:16 PM
s1cab's Avatar
s1cab
Default !!!!! Help Help Help Help Help Help !!!!!
:w all::wal l:
Hi i took my engine out of my series 1 for a respray last month everything was running fine all working ok! i got the car back and put the engine back in. it does run but its seriously overfuelling !! as in smoke/ stinks of fuel. its running cosworth management. ive changed the rotor arm, dizzy cap, leads,coil, fuel pump and timing belt. the timing is definately fine !
anyone know what could of caused this?? ive also checked that i have a correct spark and its sparking in the right order! also injectors are pulsing as and when they should!
i've heard that this could be a blocked fuel return, map sensor fault or water temp sensor faulty?? any help would be appreciated ! thanks for reading !
Old Jul 9, 2008 | 03:25 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Something is obviously different now to when it was OK - has anything changed?
The Cossie ECU will only know there's a problem with most sensors if they're disconnected, otherwise it'll just do as it's 'told'. Check they're all connected (and connected the right way up! )
Is the fuel return actually blocked? Is the CO pot on the ECU in the same place it was before you took the engine out? Has the fuel pressure regulator been fiddled with?
Old Jul 9, 2008 | 03:29 PM
s1cab's Avatar
s1cab
everything is plugged in correctly (every sensor). the co pot hasn't been touched. haven't touched regulator. a few people have said to me its a fueling problem for sure. i went torque of the devil earlier and chris todd said it could be map sensor or water temp sensor he said the water temp sensors can break with the slightest knock?? ive tried everything i can think of!
Old Jul 9, 2008 | 03:33 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
you tried another map sensor on it ?
where you located mate ?
Old Jul 9, 2008 | 03:34 PM
s1cab's Avatar
s1cab
watford. nah i havn't tried another map sensor yet.
Old Jul 9, 2008 | 03:50 PM
Turbocabbie
Top Cab !!
i run a cabby on cossie management, if you want we can get together and try my map sensor and ecu if you want to discount them.
Old Jul 9, 2008 | 04:00 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Sounds like an answer to me
That's a new one on me - they're only resistors at the end of the day. If its the same as a Cossie one, check it for the following:
Temp 'C Resistance
-40 100950
-30 53100
-20 29120
-10 16600
0 9750
10 5970
20 3750
25 3000
30 2420
40 1596
50 1080
60 746
70 526
80 377
90 275
100 204
110 153
125 102
Old Jul 9, 2008 | 04:15 PM
s1cab's Avatar
s1cab
where bouts are u from mate?
Old Jul 9, 2008 | 04:18 PM
Turbocabbie
Top Cab !!
you have PM
Old Jul 12, 2008 | 11:14 AM
s1cab's Avatar
s1cab
it was mapp sensor !!
Old Jul 12, 2008 | 11:21 AM
Miller 3's Avatar
Miller 3
Old Jul 12, 2008 | 11:29 AM
vinnyvangough's Avatar
vinnyvangough
PassionFord help wins again
