Biodiesel in Focus TDCi
Old Jul 3, 2008 | 12:40 PM
QB2's Avatar
QB2
Default Biodiesel in Focus TDCi
I am looking to blend my own Bio-Diesel to use in a 2002 Focus TDCi (115ps). Ford, tell me a maximum of 5% Bio-Diesel is acceptable. Why is this? What needs to be changed to enable the car to run on 100% Bio-Diesel?
Thanks for your help.
Old Jul 10, 2008 | 08:16 PM
cossie legend's Avatar
cossie legend
Dont use it. Its pure crap, I see problems with it everyday. It just turns into lard and blocks everything.
Old Jul 10, 2008 | 08:37 PM
Riggie's Avatar
Riggie
Series 1 RS Turbo
my brother has started to try mixing his diesel with cooking oil.... only this is in a 1.5 diesl metro lol. the test dummy car. he is mixing it 50% diesel - 50% cooking oil, so far it has run ok. obviously it will take a little for any problems to arrise, so we'll let you know.
p.s. the only down-side at the minute is the car makes you hungry... all you can smell is the chip shop!!! lol
Old Jul 10, 2008 | 08:59 PM
RS_Ant's Avatar
RS_Ant
The first thing the cooking oil will do is clog up your fuel filter so you will need a new one, other then that you should be fine i think....well as long as its filtered and made properly
Mr.T's Avatar
Mr.T
You do know there is a difference between bio diesel and veggie oil "diesel". You can run almost every car on veggie oil .Just warm it up before it gets in the pump. Thats all it needs. In the summer when its hot most of the time you don't even need to warm it. Do a search on youtube for veggie oil.
Old Jul 11, 2008 | 06:07 AM
The problem with BIO is the bacteria that live in the tanks block things by causing sludge.
Old Jul 11, 2008 | 07:06 AM
rossco22's Avatar
rossco22
Both of my Diesel's love a drop of veg oil lol
Old Jul 11, 2008 | 09:45 PM
cit-tech's Avatar
cit-tech
put it in a common rail you are asking for trouble ,it does not have the lubricants of modern fuel ,just like putting cherry in them it
do not do it ,old type diesel pumps you will get away with it 50/50
Old Jul 12, 2008 | 01:02 AM
jammy86's Avatar
jammy86
Please listen to these people ^.
Ford say a max of 5% because thats what can be commonly found in the fuel at the pump. more than this and they will NOT hold you warrenty on the engine, and they can prove that you've been using it.
JAmes.
Old Jul 12, 2008 | 05:26 AM
rossco22's Avatar
rossco22
As said its only really safe to be useing it in older vehicles ,you dont want to be putting it in a common rail engine thats for sure... Get yourself a 306 td or simlar that will love the stuff and save you a small fortune in fuel costs if you can get the oil cheap enough in the 1st place... I will only run mine on new veg oil rather than used....
Old Jul 12, 2008 | 08:47 AM
NATH-RSZT's Avatar
NATH-RSZT
as said above i wouldnt put it in a common rail diesel. yours is a common rail if you didnt know
Old Jul 13, 2008 | 10:28 PM
danny_boy699's Avatar
danny_boy699
chatter 4 life
i wouldn't mate i ran my 93 orion on it and it loved it, ran my 306 on the same stuff and it killed, ran my mondeo on it and it smokes like hell like the 306 did before it died don't do it
tankybaby66
Feb 6, 2016 02:24 PM
The Enigma
Sep 29, 2015 10:31 AM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
