Horn of not a lot!!!!!
URGENT!!! my horn has stopped working. Need it back for the MOT. Thought it might be a bad connection on the terminal so took it off and cleaned that, but still not working.
Called the Ford, sorry Fraud, dealer who said that the problem was a colck in the dash??????????
Said that part was about £30 plus a couple of hours labour!!!!!!!!!!!
Humm......total cost in that case would be about £190
Is he right or as i thought, ON DRUGS?????????
Very unlikely to be the clock spring, as said test the actual horn itself then the wiring if needed, you can always fit a NAUTILUS horn if you need a new one, a compact twin air horn set up, I have two on my cossie very loud.
Some horns have a screw on them so you can retune them, so that may be worth a try as well.
07-10-2015 12:56 PM
