Escort Cosworth MAP Sensor
Old Jun 28, 2008 | 05:31 PM
reedy's Avatar
reedy
Gods Country
Default Escort Cosworth MAP Sensor
I have a 3 bar map sensor fitted at the moment. Does anyone know the ECU pins and expected voltages for various boost levels ? Also, is it true that it has to be mounted upside down, and the case seperately earthed ?
Thanks.
Old Jun 29, 2008 | 11:54 AM
oldford's Avatar
oldford
Mounting upside down is good practice. It allows fuel to drain from the sensor.
Signal is on ecu pin 15, Ground on pin 11. Voltage level at Key On, Engine Off is approx. 1.5V at sea level. 1 bar boost (2 bar absolute) approx 3V, 2 bar boost (3 bar absolute) approx 4.5V.
Old Jun 29, 2008 | 12:55 PM
mk3stevie's Avatar
mk3stevie
Can you tell me what the 3 bar map sensro does as I have one on the 16i which is using cossie/omex management and I think it may be faulty?????
Vincereese
Jun 1, 2023 09:14 AM
manuel boeckx
13
Oct 3, 2015 02:29 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
