Rounded Head Bolts
Old Jun 21, 2008 | 12:00 PM
MJ_RST's Avatar
MJ_RST
Default Rounded Head Bolts
As title, attempting to remove the head on my zetec engine, bolts are slightly rusted, but the few i have tried have rounded (and yes i used the correct sized torx )
What options do i have now??
Is there any way i can get the bolts out?? apart from hammering in a larger torx??
cheers
Old Jun 21, 2008 | 03:50 PM
Nash_mr2's Avatar
Nash_mr2
weld a tiny nut to the top of the rounded off bit - then use a socket to get it off.
done it so many times in the past - Mig welder is best, as the heat is instant and quick so you dont risk damaging any rubbers or anything.
Old Jun 22, 2008 | 01:03 PM
MJ_RST's Avatar
MJ_RST
theres no room to weld anything to the head bolts unfort
the only options i can think of is hammering on a bigger torx and failing that, drilling the heads off
Old Jun 22, 2008 | 01:06 PM
vinnyvangough's Avatar
vinnyvangough
Hammer and hole punch?
Old Jun 22, 2008 | 01:29 PM
mk1 martin's Avatar
mk1 martin
tis gooood..
scrap it .. joking.. last option drill the head off the bolt ...done it many a time ..i feel ur pain...BIG HAMMER.
Old Jun 22, 2008 | 04:04 PM
fonfe's Avatar
fonfe
big pointed punch and a big hammer would be what id be doing or, beating on a stud extractor like this: http://img.directindustry.com/images...s-g/P24143.jpg
beat it on as straight and as far down as you can then turn it with a breaker bar. once your crack the bolt off go forwards half a turn then back half a turn just to get the thread going agian then just undo it all the way. best tool i ever bought was a set of these.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
hopper350
Sep 4, 2015 12:53 AM
