Engine cutting out
Old Jun 18, 2008 | 03:13 PM
17-APG's Avatar
17-APG
Default Engine cutting out
You may remember that I posted a problem where the engine of my 4x4 sapp cossie was cutting out; not misfiring but completely cutting out. Well, I resolved the problem at the weekend and it was so simple.
There is a little pipe running from the inlet manifold to the map sensor which is bolted onto (facing down) the inner wing. The 90 degree rubber bend was almost off the sensor. I pushed it completely home and now ...JOY
Old Jun 20, 2008 | 05:34 PM
LHD220Turbo's Avatar
LHD220Turbo
its always the easy things; the pipe to the MAP sensor is vital
Old Jun 20, 2008 | 05:57 PM
17-APG's Avatar
17-APG
You are so right. I had already fitted new plugs, leads and a fuel filter to try to cure the problem. But hey it's great to have it firing full steam now when I floor it!!
Old Jun 20, 2008 | 07:19 PM
LHD220Turbo
3drRich
Sep 13, 2015 07:32 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Bailes1992
Aug 16, 2015 07:14 PM
track.focus'd
Aug 12, 2015 05:53 PM
