lamba sensor conversion
Old Jun 16, 2008 | 05:20 PM
dom123's Avatar
dom123
Default lamba sensor conversion
i'm currently doing a closed loop conversion and i'm geting the lamba sensor welded in tomorrow, where has every one else fitted theres? i was thinking on the top before the down bend just after the turbo? anygood?
cheers
Old Jun 17, 2008 | 04:07 AM
stevecossy's Avatar
stevecossy
Yeah thats where most people av em buddy,
Old Jun 19, 2008 | 05:00 PM
juffer's Avatar
juffer
apparently there ment to go about 2foot after the turbo due to the heat as it will not read corectly i had a fitting guide somwhere ill find it if you like
Old Jun 19, 2008 | 05:08 PM
KSA-Cossie's Avatar
KSA-Cossie
Mines fitted into the turbo
Old Jun 19, 2008 | 05:55 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
std is in the turbo itself....
Old Jun 19, 2008 | 05:59 PM
Stu @ M Developments's Avatar
PassionFords Creator
Thats Rubbish Mate, ignore it. The sensor element itself is hotter than the turbo in the first place. Just prior to teh bend is fine, and it must be mounted between 9 and 3 oclock, no lower.
Old Jun 21, 2008 | 09:48 AM
foreigneRS's Avatar
foreigneRS
Testing the future
the sensor has to be at 750 deg. C to work, that's why most of them are electrically heated
Old Jun 21, 2008 | 04:23 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
All you have to do is look where Ford mounted theirs in the cat-equipped cossies - in the back of the turbine housing!!
Old Jun 21, 2008 | 04:42 PM
Roosie's Avatar
Roosie
500bhp Cosworth in making
what about EGT sensors were are they best to go?
Old Jun 21, 2008 | 04:47 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Depends what you want to measure.. Technically you want it before the turbine, so you can measure the turbine inlet temperature.. but some people are worried about TC probes breaking and damaging turbos (never seen it personally).. If you put it after the turbo you have to factor in the temperature drop across the turbo.. So perhaps you could measure it before and after and then remove the pre-turbo sensor if you're worried about breakage.. at least then you KNOW the drop across the turbo
Old Jun 21, 2008 | 04:53 PM
foreigneRS's Avatar
foreigneRS
Testing the future
get a proper inconel thermocouple and they can withstand 1200 deg. C - if it's that hot in there you have more to worry about than turbine blades
Old Jun 21, 2008 | 04:55 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
You say that, but the turbocharger in the Focus ST is rated to 1100C!! Triple-pass cats run pretty damn hot!! (although not quite 1200C )
Old Jun 21, 2008 | 07:14 PM
Roosie's Avatar
Roosie
my car is going to be running off egt not lambda from emerald so it needs to be bloody damn accurate
Old Jun 21, 2008 | 07:50 PM
It's set up with lambda and egt to start with so egt is then just a safeguard, after turbo is fine, and where mine is going, Reylan dis out of them but have now tracked own part numbers and price(£113).
Old Jun 21, 2008 | 08:05 PM
foreigneRS's Avatar
foreigneRS
Testing the future
but EGT is not a safeguard in my understanding as you might think that the temperature going down indicates safe mixtures and conditions, but it does not necessarily
Old Jun 22, 2008 | 03:48 AM
It's a damn sight safer than a lambda as it reacts so much quicker.
Once set up unless other factors alter, this will give the earliest warning of anything amiss engine/fuelling wise.
Old Jun 22, 2008 | 08:16 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
From my experience, thermocouples react slower than wideband lambda sensors.
Old Jun 22, 2008 | 08:43 AM
foreigneRS's Avatar
foreigneRS
Testing the future
depends on the TC - you want a nice fat one for strength and reliability, but that wouls have a slower response time than a thin one
Old Jun 22, 2008 | 08:49 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
I don't think you can really rely on any one sensor, be it lambda or temperature.. both can mislead you, it's what you do with all of the sensors and your own knowledge that counts!
Old Jun 22, 2008 | 11:54 AM
foreigneRS's Avatar
foreigneRS
Testing the future
spot on mate - knowledge is king and having more sensors allows you to make a judgement based on that knowledge
Old Jun 22, 2008 | 04:16 PM
I have the option of neither, 1, or both, so might as well use the Tech Edge I have as well as a egt.
Old Jun 23, 2008 | 08:34 AM
Ive never seen one that reacts quicker.
In fact, im damn sure they dont exist mate.
Old Jun 23, 2008 | 09:15 AM
You are entitled to your opinion as everyone else is, you stand more chance of being correct than I do, but you are not always correct, that's the good thing about opinions, it is just that.
Old Jun 23, 2008 | 09:58 AM
Thats exactly why if i am unsure i make it clear that its only a opinion.
Your reply stated it as a fact.
Old Jun 23, 2008 | 10:43 AM
Read what is written about using the forum then, views expressed are just that, views ie opinions, the same with any forum, nothing is a cast iron gaurantee.
The person I trust will be doing my mapping/s so this is a bit irrelevant anyway now.
Old Jun 23, 2008 | 10:47 AM
That helps the topic starter no end. Great input.
Old Jun 23, 2008 | 12:12 PM
silky16v's Avatar
silky16v
Get on That!
fuk me you would argue black is blue and honestly believe it was
100% Take Stu's advice Dom123
Old Jun 24, 2008 | 08:02 PM
Phil2002's Avatar
Phil2002
spot on
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
fordrallycar
Sep 30, 2015 07:57 PM
SMILER258
Sep 28, 2015 09:04 AM
