plenum spacer!!! plz help!!!
Old Jun 14, 2008 | 02:07 PM
dom123's Avatar
dom123
Default plenum spacer!!! plz help!!!
hiya ive just bought a 10mm plenum spacer for my sapphire cosworth, fited it now gone to put the injectors in and the rail does like up atall it and the injectors wont fit, also the bottom bolt on the plenum to the engine mount doesn't line up either this is a nightmare!!! someone must have had this problem. any help would be great. cheers
Old Jun 14, 2008 | 02:21 PM
Stu @ M Developments's Avatar
PassionFords Creator
The YB really needs a 14MM one or you have all of the above problems mate. Send it back and get the right one.
Old Jun 14, 2008 | 04:43 PM
dom123's Avatar
dom123
thanks for your reply, where can i get one from, i cant find them anywhere?
cheers
Old Jun 14, 2008 | 05:43 PM
DazC's Avatar
DazC
Try Ferriday.... 14, 15 or 16mm spacers are the sizes that will work with a standard plenum.
http://www.ferriday.co.uk/orders/man...adaptors.shtml
Not sure on what thickness they are but a quick phone call will soon get you that information.
Old Jun 14, 2008 | 09:33 PM
dom123's Avatar
dom123
thanks is there anywhere else that do these ,i'm not going to £100 on a piece of aluminum!!!lol
cheers
Old Jun 14, 2008 | 11:33 PM
IAN RS2k's Avatar
IAN RS2k
Ive got a 10mm one on mine you just have to file 4mm off the back of the mounting stub it doesnt stop you putting it back to standard. As for the mount its the same with them all you just have to slot the holes if you go for the 14mm one it would be worse on the mount.
IAN
Old Jun 15, 2008 | 09:10 AM
dom123's Avatar
dom123
ok thanks mate i'll have a look today i'll do that, just wish the item was discribed that way in the first place lol
cheers
steve.rst
Mar 15, 2016 08:01 AM
stephenb4506
33
Oct 2, 2015 06:25 PM
mondeomark
Sep 28, 2015 06:28 AM
IainRS1700T
Sep 25, 2015 06:44 AM
timsrs
22
Sep 24, 2015 08:14 PM
