rs2k idle fault
Old Jun 12, 2008 | 09:52 PM
stevielgt's Avatar
stevielgt
stevielgt
Default rs2k idle fault
my mk5 rs 2000 wont idle properly, if you rev it for a about a minuate it will just about idle but its irratic and trys to stall. if you turn it off and start it again it wont idle till you rev it for a about a minuate again. its got a brand new idle control valve and throttle position sensor also a new air mass sensor and absolute air pressure sensor, and iv checked the wiring best i can,
Old Jun 13, 2008 | 05:41 AM
Check for air leaks and lambda value, if it is even slightly off fit a new lambda, cheap from eco lambda.
I did a few cars recently with eco lambda's ALL perfect now, despite ALL having readings within scale before, obviously switching was slow on old ones.
Old Jun 13, 2008 | 05:42 AM
nickscunny's Avatar
nickscunny
Idle Control Valve or Air by pass valve as its better known on the rs2k........
tankybaby66
Feb 6, 2016 02:24 PM
fordrallycar
Sep 30, 2015 07:57 PM
RSmark84
Sep 13, 2015 01:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
