3dr Abs Loom Help
Old Jun 7, 2008 | 09:44 AM
COLEYST200's Avatar
COLEYST200
Default 3dr Abs Loom Help
HI lads can any one help please im building a 3dr cosworth and the yellow plug for the ABS is down in the drivers side of the car and i cannot see where to put the ABS brain and the loom for the ABS is as one with the car loom . ive just been told on the phone that the ABS has its own loom and the brain gose under the ECU on the pasinger side the photo shows where the plug is at the mo and there is no way it will move over to the pasenger side can anyone put any light on this for me please
Old Jun 7, 2008 | 10:17 AM
PAUL S's Avatar
PAUL S
On a 3dr the abs ecu and fuseblock for it sit in a little carraige bracket which then bolts up above the footwell on the drivers side - I dont see the bracket in your photo, the ecu actually slides into it.
tankybaby66
Feb 6, 2016 02:24 PM
muz
Sep 30, 2015 08:29 AM
