Quick battery to boot conversion question
Old May 30, 2008 | 08:58 PM
McGoo 69's Avatar
McGoo 69
Default Quick battery to boot conversion question
Just a quickie
whats size cable should i be using to do this?
how do i go about earthing in the boot?
im i best using a junction box in the engine bay to extend the cables to the boot, or a total rewire on the positive and negative side from the start/alternator
thanks matty
Old May 31, 2008 | 09:18 AM
McGoo 69's Avatar
McGoo 69
anyone? would like to do this conversion today
thanks matty
Old May 31, 2008 | 09:25 AM
Bomber's Avatar
Bomber
I would probably replace the entire run from Battery to starter. Saves faffing about then. What ever you do, buy proper starter motor cable NOT car amp audio power cable.
For earthing in the boot - i used the spare wheel nut (it's used to hold the spare wheel in the boot of a Mk1 fiesta) and bolted a nice fat (15mm) earth lead to that. Not had any earth problems.
Old May 31, 2008 | 09:26 AM
Bomber's Avatar
Bomber
Oh also forgot: Merlin do the right cable you need. I'd ring them up and ask what ampages/diametre they suggest for your application.
http://www.merlinmotorsport.co.uk/ad...keywords=cable
Old May 31, 2008 | 09:27 AM
Miller 3's Avatar
Miller 3
Think i used 300A wire iirc and used some big rubber bushes under the bonnet to put the cables on to' Then a cover to stop any eathing out.. In the boot i just went down to the floor pan with a 19mm bolt'
Old May 31, 2008 | 12:32 PM
McGoo 69's Avatar
McGoo 69
im a sparky so i have alod of house hold stuff.
10mm cable should be ok shouldnt it?
Old Jun 2, 2008 | 02:59 PM
Aaroncast's Avatar
Aaroncast
the best cable to use is mig/arc welding cable--
put battery into a battery box(blue book!!) earth down off the post to the boot floor ,your now earthed!!!.
do you need a battery-F,I,A cut out with /without shunt???AS PER BLUE BOOK??
RALLY RACE ETC!!.
more yet but depends on your answer!!!
Bransby
Sep 11, 2015 01:09 AM
andrewmctiernan
Sep 8, 2015 03:05 PM
chris m1
Sep 7, 2015 08:02 PM
cameron2
Sep 6, 2015 10:40 AM
Adam Graham
Sep 6, 2015 06:04 AM
