covertin to coil pack
Old May 27, 2008 | 01:18 PM
rsturboismine's Avatar
rsturboismine
Question covertin to coil pack
Hi all,
I have just bought me a 2.0 zetec blacktop which I am going to fit into my S2 turbo. (yes I know to lower compression),I am unsure how to convert from my standard cvh dizzy so that i can use the zetec,s coil pack.
Can anyone help me please or i will have to go the zvh way like the majoraty. Thanks.
Old May 29, 2008 | 05:04 PM
fonfe's Avatar
fonfe
not quite sure what you mean mate, if your planning on running zvh then no you just keep the rst dizzy as it is on the cvh head. if your going full zetec then the coilpack stays on the zetec and whatever aftermarket management will trigger the coils. (they have a permanant live to them and the earth for each side pulse to trigger aka. negative triggerd)
Old May 30, 2008 | 02:33 PM
rsturboismine
Exclamation
Hi I am going full zetec but i want to retain the standard management as it is chipped and just use a fith injector the problem is that the cvh uses a dizzy and the zetec uses a coil pack. So does anyone know how to convert my existing loom to use a coil pack.
Old May 30, 2008 | 04:11 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Er, you can't really. I'd speak to a tuner for advice as you're going about this the wrong way.
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
KennyWelsh
Ford Focus (All Models)
Sep 13, 2015 08:28 PM
