temp prob still there
Old May 27, 2008 | 11:56 AM
orion88's Avatar
orion88
Default temp prob still there
so the previous owner has completely bypassed the fan switch on the thermostat and just chopped the fan wires at the fan and ran them straight to a swithch in my dash however the temp sensor is on the head isnt it?sure its that push on one that goes next to the manifold but obviosly hwhen i push this on the temp readout on my dash shoots straight to the top so folks how on earth can i get a real temp readout cos im stumped ideally i want the fan switch to work as well but i will settle for just a temp readout so i know how hot its running
really need your help here people
Old May 27, 2008 | 03:08 PM
rickbartlett's Avatar
rickbartlett
G911 TTA
U Need A New Temp Sensor Mate.if U Wiggle It I Will Probably Move Down But Wont Stay There.its Obviously Faulty Mate
Old May 28, 2008 | 09:06 AM
orion88's Avatar
orion88
what does it look like?is it one of the multiplug bits that one of the colour coded plugs fit onto and how hard is it to swop?
Old May 28, 2008 | 11:19 AM
picky775's Avatar
picky775
its a little brass sensor with a plug on it next to the manifold as you said....just unscrew it from the head and screw a new one in,then refill header tank as you will lose some water.job done
Old May 28, 2008 | 11:25 AM
LHD220Turbo's Avatar
LHD220Turbo
assume your talking about a cosworth? - i had the exact same problem as you on the weekend; started the engine and the temp gauge was in the red
the temp sensor is at the fron of the head on exhasut side with a single wire connected to it.
take single wire off, you'll need 1/2 inch spanner to undo the sensor, refit a new one and job done, you will loose a little water so have the new one in your hand ready!
refill header tank if need be
PS the sensor is white from memory
reconnect wire....job done
Old May 28, 2008 | 11:37 AM
orion88's Avatar
orion88
its an rs turbo
i had the problem on my other head aswell tho surely 2 heads cant be duffas
where does the wire go?from memory its a brown and white wire but i cannot trace it.does it need earthing?
Old May 29, 2008 | 08:35 AM
orion88's Avatar
orion88
woo hoo all fixed
Mark RS
Oct 12, 2015 06:01 AM
gcfcos
59
Oct 6, 2015 05:04 PM
gcfcos
88
Sep 15, 2015 03:48 PM
Ben26
Sep 3, 2015 07:55 PM
