Boost control
Old May 26, 2008 | 07:46 PM
snoopaloopa's Avatar
snoopaloopa
Default Boost control
Hoping someone can help, I want to fit electronic boost control to my twin turbo, are there any boost controllers that can control 2 turbos or do i have to get 2 controllers ? Only looking to control about 1 bar, any pointers in the right direction much appreciated as i'm new to the turbo path
cheers
Old May 28, 2008 | 06:51 PM
snoopaloopa
Obviously a a bit too technical then
Old May 28, 2008 | 07:47 PM
LHD220Turbo's Avatar
LHD220Turbo
twin turbo what?
Old May 28, 2008 | 07:56 PM
G750 NDS's Avatar
G750 NDS
24v BOA,
Ian
Old May 28, 2008 | 08:34 PM
snoopaloopa
Originally Posted by LHD220Turbo
twin turbo what?
Didn't think it would matter tbh but its twin turbo xr4x4 12v cologne, running Turbo Technics T2's
Old May 29, 2008 | 06:28 AM
If you combine the actuator feeds then it will work fine.
Old May 29, 2008 | 04:45 PM
snoopaloopa
as in 't' them together and then use 1 controller ? I did think that would be ok but wanted to make sure
thanks
Old May 30, 2008 | 07:38 AM
So long as you ensure they are equally set/matched boost wise will be fine.
Old May 30, 2008 | 04:19 PM
snoopaloopa
ok
thanks
Old Jun 3, 2008 | 11:22 AM
legend289's Avatar
legend289
When i was building a twin turbo V6, Dave Walker said the way to do it was to use N74 valve(aVW/Audi part) to control the turbos. Contact him at Emerald website, he`s really helpful.
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
