RS Turbo washer jets not working
Old 24-05-2008, 03:38 PM
S2Steve
S2Steve's Avatar
Default RS Turbo washer jets not working
They were working one day, and not the next. I had a fiddle with relays and think its the big red one in the fuse box. I can feel it clicking when I push the washer button in, but nothing squirts. Its full up and worked yesterday. Any ideas? Could the stalk have broken? I swapped the relay for another one i bought in bulk a while ago and it clicks but nothing still.
Old 24-05-2008, 08:12 PM
anodised
anodised's Avatar
have you tried cleaning the jets out with a small pin
Old 24-05-2008, 08:19 PM
S2Steve
S2Steve's Avatar
No, not contemplated that, I assumed that wouldn't be the prob since they were working fine, then next morning they weren't
Old 24-05-2008, 10:24 PM
crash_ash
crash_ash's Avatar
put you test meter on the plug for the washer pump to rule that out
Old 25-05-2008, 04:13 PM
S2Steve
S2Steve's Avatar
Don't have a meter mate.
Old 25-05-2008, 08:25 PM
JohnnyP
JohnnyP's Avatar
the motor in the washer bottle is probably nackered, i had a black rs which done that and it was the pump in the bottom of the bottle, i mite b able to get hold of 1 ta morra!
Old 25-05-2008, 08:49 PM
S2Steve
S2Steve's Avatar
If you could mate, would be awesome. Even if it turns out not to be the prob, spares for an RS are always handy lol
Old 28-05-2008, 05:16 PM
S2Steve
S2Steve's Avatar
When you press the button in, you can feel the realy click. I'm in the process of trying to get the bottle out, its a shame ford had to place it in such a ridiculous place to be honest!
Old 29-05-2008, 10:10 AM
S2Steve
S2Steve's Avatar
Right so i've found the problem, the pump under the bottle isn't working! Anyone got a spare?!
Old 29-05-2008, 10:15 AM
c.h.r.i.s
c.h.r.i.s's Avatar
is it the same as a mk6 escort? if so i have one you can have. just pay the postage
Old 29-05-2008, 04:56 PM
fonfe
fonfe's Avatar
before you buy a new one run two wires straight from the battery and see if that kicks it into life. had this problem and just giving it a staight 12v feed broght it back to life then just plugged it back in using the original conector and it worked again so may be worth a try mate. could just be somethings got stuck in the motor.
Old 29-05-2008, 05:21 PM
xrmalin
xrmalin's Avatar
check the wires that run down the tank to the pump aswell as ive had one thats worn through the wires over time of it rubbing against the inner wing.
3i Jim
20-11-2015 05:12 AM
Billy_RS
15
05-09-2015 12:04 PM
Michael Wisbey
14-08-2015 11:57 PM
RUBY123
14-08-2015 09:26 PM
Quick Reply: RS Turbo washer jets not working
