erst rear brake conversion
Old May 20, 2008 | 12:23 AM
xrcabby's Avatar
xrcabby
Talking erst rear brake conversion
hi
im about to do a rear brake convesion on a s2 i have the brakets i just want to know wat diffrent calipers i can put on also wat parts do i need cuz i read on a forum tht u need the hubs aswell? can focus or mondeo calipers be used.g
Old May 20, 2008 | 05:42 AM
As you have the brackets you should only need the calipers and discs(xr4x4?).
I assume the brackets you refer to are the ones to go onto the hub so that the slider from the caliper can bolt onto it ?
Old May 20, 2008 | 12:17 PM
xrcabby's Avatar
xrcabby
yeah they are the ones tht bolt on to the hub so is it only seirra calipers tht fit also wat hoses do u use?
Old May 21, 2008 | 08:58 AM
NUTS RuS's Avatar
NUTS RuS
Any 4 stud Sierra rear calipers and discs (solid type not vented)
Escort Mk5 RS2000 handbrake cable then you need to swap the front part over from your original cable.
I have multi fit longer braded lines available for £12.50 each
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
cossirob
Sep 3, 2015 09:17 PM
