Escort rs turbo smoke rings???
PassionFORD Member
horrible grey smoke would lead me to believe incomplete combustion. and its only on idle? have you had mates following you to tell you what it does on load and on/off boost?
p.s. this is proper greyish/black smoke right, not just clearish smoke that fords make on idle?
PassionFORD Member
hmm. not very experienced on this sort of thing but can check simple things like spark plugs if they are fouled. it could be a problem either with ignition or fuelling but I would hazard a shot more at the ignition side. Someone else I'm sure would be of better help then I am.
muz
16-08-2015 12:57 PM
