Zetec pinking and stuttering....
Old May 17, 2008 | 11:11 AM
Ade's Avatar
Ade
Fast Ford snapper
Default Zetec pinking and stuttering....
MK4 Escort with a N/A 2.0 Zetec running a DESK ECU.
Always had quite a stutter when initially applying power and also when changing gear (any time when power is applied from zero throttle really).
Recently its started pinking under load at mid to high revs in 4th and 5th.
Quite odd as I didn't think pinking would be possible with this setup, and it doesn't happen at low revs or gears either..... can't even provoke it at any other times and it doesn't even do it consistantly...any ideas?
Could an air leak casue this?
Old May 17, 2008 | 02:38 PM
fonfe's Avatar
fonfe
could be that you have a hole in the vacume hose from bgelow the thermostat housing to the inlet manifold. i had this and it caused the car to run really lean as it was sucking in air so may be worth you checking that its all ok.
Old May 17, 2008 | 08:05 PM
Ade's Avatar
Ade
Fast Ford snapper
Could be something like that....... dodgy inlet manifold gasket etc maybe?
Old May 20, 2008 | 12:52 PM
fonfe's Avatar
fonfe
sort it?
Old May 20, 2008 | 07:26 PM
Ade's Avatar
Ade
Fast Ford snapper
was about it today... can't find anything wrong
Old May 21, 2008 | 06:15 PM
fonfe's Avatar
fonfe
dunno then mate without seeing the car im afraid
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
SMILER258
Sep 28, 2015 09:04 AM
mondeomark
Sep 28, 2015 06:28 AM
focuspower
Sep 20, 2015 03:51 AM
