Datacable for Omex 100
Old May 12, 2008 | 02:04 PM
javierant3's Avatar
javierant3
Default Datacable for Omex 100
Hello everybody, recently I have purchased in Ebay a Omex 100 ignition Ecu, complete with wiring harness, but I don`t have the communication cable for the PC.
Is that cable special for Omex? or I can use a standar serial Port Cable for communication with the ecu?
Old May 12, 2008 | 02:21 PM
Will possibly be a RS232 cable, so fairly standard, but I am by no means 100% sure.
Old May 12, 2008 | 04:44 PM
flashpoint's Avatar
flashpoint
yes it is rs232 bu you must make Sue you get the right one, pin 2 must go to pin 2 ant each end of the cable as far as i can remember contact omex for clarification
Old May 12, 2008 | 05:57 PM
javierant3's Avatar
javierant3
Then if I buy a rs232 cable from computer store, can do the trick? or the pins are different?
155lee
Oct 27, 2015 04:55 AM
Mark RS
Oct 12, 2015 06:01 AM
Steve Escos
Oct 1, 2015 06:57 AM
dombanks
Sep 21, 2015 08:38 PM
Tank Mike
Sep 14, 2015 03:56 PM
