Wiring bods
Old May 11, 2008 | 07:53 PM
Miller 3's Avatar
Miller 3
Default Wiring bods
Rewiring my fuel pump today and using the old wires as a trigger to a relay and when i test the live i am getting 9v or so for a split second then it drops to 0.30v
Please help
Old May 11, 2008 | 08:47 PM
Miller 3's Avatar
Miller 3
Old May 11, 2008 | 09:04 PM
Do you mean the original feed drops to 0.3 volts, after a split second ?
If so this is normal as the prime, and initial voltage stops, test it RUNNING.
Old May 11, 2008 | 09:10 PM
Miller 3's Avatar
Miller 3
Yes thats right Tabs cheers
I was thinking that at this point it would not be under any load and want to put volts down the wire.
Thanks again fella
Old May 11, 2008 | 10:05 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
he cant test it running yet
Old May 11, 2008 | 10:35 PM
Miller 3's Avatar
Miller 3
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
cossie brad
Sep 29, 2015 02:38 PM
IainRS1700T
Sep 25, 2015 06:44 AM
