ACT Gauge Wiring
Old May 11, 2008 | 07:54 AM
ickey818's Avatar
ickey818
Default ACT Gauge Wiring
Hi all,
Have just brought an air charge temprature gauge for my cosworth which I'm hoping to fit sometime this week.
My question is has anyone wired one of these into the existing air charge temprature probe which the ECU uses? This would make installation a lot easier as I don't have to run any wires into the engine bay and find a suitable place to fit the new probe.
Also if anyone has done this can they tell me which pins on the ECU plug I should be wiring into?
Thanks
Old May 11, 2008 | 08:05 AM
NEEDFORSPEED's Avatar
NEEDFORSPEED
no you cant
Old May 11, 2008 | 02:23 PM
YES you can, BUT only if the resistance of the gauge matches the air temp sensor otherwise it will read wrong.
Old May 12, 2008 | 05:12 PM
ickey818's Avatar
ickey818
How do I find out the resistance of the temp gauge and my current air temp sensor? Can I do this with a ohm meter?
Old May 12, 2008 | 05:51 PM
NEEDFORSPEED
have the sensors next to each other at room temp and simply read the resistance of them both then subtract one from the other then get a resister the size of the difference. will only work 1 way tho obviously (the resistance of the standard sensor needs to be larger than the other).if not then its not worth doing youl have to make a circut to make up the difference.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
IainRS1700T
Sep 25, 2015 06:44 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
